Also Does it have to be 28 spline exactly to work?
3.73s
Originally posted by A-drain View PostOk so just to be really sure I need one of these. http://www.latemodelrestoration.com/...FcqVfgodXqwAFQ and the ring and pinion kit from the first post for the whole job?
That's a 31 spline, you need a 28 spline.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
31 spline no workie. It must be a 28 spline.86 Lincoln Town Car (Galactica).
Originally posted by packman View PostUnless you're stuck on a few inches of ice. Then you don't go anywhere no matter what you got. :o
http://m.americanmuscle.com/ford-rac...-28spline.html so this one for sure? 28 spline, 8.8 rear, trac loksigpic
Originally posted by A-drain View Posthttp://m.americanmuscle.com/ford-rac...-28spline.html so this one for sure? 28 spline, 8.8 rear, trac lok
yes, the 28 spline one. You link says not in stock though... so good luck finding one.
I think the new Mustangs run a 31. The 28 may have gone out of production.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThe 28 may have gone out of production.
The 28 spline trac-lok units can be found all day long on ebay, Craigslist, junkyards, etc. and since they are used, they are cheaper.1989 Country Squire - Twilight Blue, 347 stroker
imo not a job to someone who has never done it before. you need a shop press and a dial indicator and a 1/4" beam torque wrench to start with.
you will want to pick up a bearing kit, axle seals and bearings, and a 28 spline traction lock.
