Yeah, I think its a 1/2" spacer.
Valve Covers in a Box w/ 351W
Thanks! I just ordered a 1/2" spacer. I've got the same valve covers on my 87 F150, but that intake is high above the valve covers...would have been a surprise on the CV for sure! I used a breather style cap, and it's a SD truck, so there's no unmetered air to worry about.Last edited by bgreywolf; 05-23-2019, 03:01 PM.
mine is mass air, so it needs the connection.86 Lincoln Town Car (Galactica).
click the link that says "use basic uploader" at the bottom right of that window. The select the file and then click upload file. bit of a PITA to upload one at a time, but it does work that way.
Originally posted by 87gtVIC View PostDid you have to run an intake spacer in order to for the upper intake to clear the valve covers?
a miss is as good as a mile.
Originally posted by sly View Postclick the link that says "use basic uploader" at the bottom right of that window. The select the file and then click upload file. bit of a PITA to upload one at a time, but it does work that way.
What browser are you using?
and thats basically what the factory 351 cars came with. Boring-ass tin covers, nothing remotely special. The efi lopo covers are actually a little nicer, just because they're thicker metal. They also have a decent amount of room inside and can be had for peanuts.86 Lincoln Town Car (Galactica).
Yeah, next time I do this (which I hope is no time soon), I will wait to get the parts I think I will need. I got the valve covers years ago at a swap meet; after I discovered that all I needed was an intake spacer to make taller-than-stock valve covers clear the upper intake. I knew they were for a carb'd application, but I figured that I could make them work with EFI; didn't anticipate fitment issues like this :-/
