I have one out of a 2003 and the length seems right, but its out of a police car, so its got the big-ass U-joints. I know with my Mustang, in order to use the driveshaft out of the Aerostar, I had to use an adapter U-joint, that is big on one pair and smaller on the other, works mint, wondering if the same joint would work on mating the PI driveshaft to the factory yokes.........
Stock aluminum driveshaft.
It probably will, the D/S's and flanges are pretty much the same on most fords. There is a good chance though, that the stock steel shaft has the big pattern also.Builder/Owner of Badass Panther Wagons
Originally posted by mrltdIt probably will, the D/S's and flanges are pretty much the same on most fords. There is a good chance though, that the stock steel shaft has the big pattern also.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Is there actually any seat of the pants increase going to a alum driveshaft on a stock box? I know it saves a few pounds but is it actually noticeable1999 CVPI
Old Rides
1988 Ford Mustang GT (trickflow stage 1)
1989 Mercury Grand Marquis LS (5.SLO)
1989 Ford Thunderbird SC (3.8 Supacharged)
Originally posted by mrltdYes, my pants don't vibrate as much.
HHAHAHAHHAHHA Exactly
Reduces vibration from rear-end gear changes. The aluminum driveshaft works as a damper, unlike the steel one1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Hmmm I shoulda got the one off the '87 P72 that they drove into the junkyard... $20. Dang it I kick myself for so many things I should have bought and didn't.1990 Country Squire - weekend cruiser, next project
