I've done them with the jack under the control arm and the hammer method to separate the ball joint. I also stand in front of the car to lower the jack, just in case.
--Quick Question-- About Wagon Springs
Bringing this back to the top---
Another quick question though
For the rear I ended up getting MOOG 8795
Part Number 8795
Inside Diameter 5.000
End Type 1 Pigtail
End Type 2 Pigtail
Bar Diameter 0.625
Install Height 12.69
Load in Pounds 790.0
Spring Rate 182.0
Free Height 17.04
Rear Coil Springs
I have about 110 pounds in the trunk, give or take 10 pounds, what would be the best way to match up front springs so the car sets pretty level?
Front Springs:
Base: 374lb/in
Wagon: 443lb/in
HPP: 540 lb/in
P71: 700 lb/in
Rear Springs
Base rear coils: 107 lb/in
Wagon rear coils: 182lb/in
P71 rear coils 160 lb/in
HPP bags ~110 lb/in nominal
Front Springs:
Base: 374lb/in
Wagon: 443lb/in
HPP: 540 lb/in
P71: 700 lb/in
What springs could I get that would be about in between both base and wagon, I am thinking maybe about 400-415lb/in springs. That would probably be perfect seeing that I have 100+ pounds in the trunk at all times. If you guys need me to do anymore measurements I can't do any until Friday night I am in Colorado Springs at the moment, it is nice here but it is kind of cold and rainy.
Stock Towncar springs are like 390 in/lb but they'll be slightly higher. If you use the HD sedan coils, you'll keep the same ride height and get the higher rate. I have them on my car, and the ride is anything but harsh. The change from stock rate to the HD coils is not enough to severely affect ride. Shocks can change it more to be honest. Actually on a Towncar, the HD coils make the front end a tad lower than stock since they have a slightly shorter free height than a Townie spring, and Lincolns have an extra front chassis brace and another foot of body hanging past the wheels.86 Lincoln Town Car (Galactica).
Originally posted by saiyaneye View PostSo the rating has nothing to do with the height, I am confused? Is the install height all i have to worry about? How do I determine this if I am to choose different springs not listed on the list MrLTD posted?
Spring rate is a measure of the resistance of the spring to compression. If a spring is rated at 500 lb/in, that means that a load of 500 pounds will compress it one inch. A load of 1000 pounds will compress it two inches. Spring rate is determined by a little formula that takes into account the diameter of the wire, the diameter of the coils, the torsional modulus for steel, and the number of active coils, and basically has nothing to do with the height of the spring.
Obviously, a 14" spring with a rate of 500 lb/in will compress to a length of 12" if a load of 1000 pounds is applied.
Spring height (free height) is just how long the thing is. This will generally change over time when a spring "sags", but the spring rate will not change unless one of the inputs to the spring-rate formula changes, usually the number of active coils in the event you cut a coil or so to make it shorter. This is why cutting coils will result in a slight increase in spring rate but sagging springs do not change the rate at all.
To make things even more fun, unless the spring is able to act on the wheel directly over the tire's contact patch, the effective spring rate at the wheel is less than the actual rate of the spring. There's a formula for that as well, but I'm not sure if anyone here has made the measurements required to put it to work on a Panther. If it happens, I'd guess Blaze86Vic would be the first to do it.2012 Mazda5 Touring | Finally working on the LTD again!
So like gadget73 said, the shocks can/will affect the ride height as well. If they do would it probably be .25-.5? or less? J/w
Also does anyone here have damn near stock Vic or Merc w/ HD Coils on the front? If so can you take a measurement for me.
