thanks
what is 91 canadain marquis stock offset rim?
Tags: None
the same as any other 79-02 panther .....
and which is posted in THE FAQ AT THE TOP OF THE PAGE.....titled : SUSPENSION/DRIVETRAIN FAQs *READ BEFORE POSTING* OR I WILL DESTROY YOU
Suspension, Chassis, Drivetrain, Brakes. Everything to do with handling. Also includes transmission discussions.
Wheel Sizes/Offsets: (From '89 Shop manual)
(Thanks to 89GrandMarquis)
Town Car
Steel 15x6 Offset=0.45" Tire=P215 70R15
Alum (cast lacy spoke) 15x6 Offset=0.35" Tire=P215 70R15
Alum (cast turbine spoke) 15x6 Offset=0.45" Tire=P215 70R15
Alum (cast wire spoke) 15x6 Offset=0.35" Tire=P215 70R15
Crown Vic/Grand Marquis
Steel police 15x6.5 Offset=0.35" Tire=P225 70R15
Alum (cast) 15x6.5 Offset=0.45" Tire=P215 70R15
Steel 15x6.5 Offset=0.45" Tire=P215 70R15
