Anyone have any idea what a garage should be charging in labor (roughly how many hours worth) to replace front and rear suspension bushings on a 1989 Colony Park?
I was thinking of staying pretty much stock but if anyone has suggestions, I'm all ears. Have been considering tackling the job myself but its been a long time since I crawled under a car.
poly bushings are available, and will last much longer than the factory replacements, cost less and are easier to replace. Got lots of info in the faqs and the forum.....
poly bushings are cheaper and easier to install......15-20 hrs is about right to replace front and rear bushings
to answer the question asked in the other thread, I will reiterate the"read the faqs" and add that the rear bushings are the 92-97 application from energy suspension. Energysuspensionparts.com
Stock bushings are a PITA to replace, quite labor intensive. I can believe a 20 hour bill for that. Poly anyone can do, only special tool you really need other than the torch is a spring compressor to put the springs back in. I've been driving on poly bushings for pushing 3 years now, no complaints or problems with them. They are a bit firmer than stock, but its not harsh and it does firm up the handling quite a bit.
