Ok, the BBS process on my 82 panther is almost done. (Gathering all the parts that is.) I have a bad master cylinder. Which year make model should I use when I buy a new one??? Should I Get one for the 1982? Or, for a 1998-2004 panther since the front BBS brake parts are all from a 1998-2004 panther? If I go with the 1982 master, then I know Ill be ok with the rear brakes. However, If I go with the 1998-2004, then How will it react with my rear drums? Please advise. Thanks.
BBS preparation 90% completed / Master cylinder info.
Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
sigpicTags: None
I'd replace it with a stock one. It will bolt right in and work fine with the big brake parts. I'm running an original 1986 MC on my car.86 Lincoln Town Car (Galactica).
stock master cylinder is fine
Perfect. Thank youVehicle: 1965 Pontiac Catalina (fastback 2+2)
From my experience, if the master cylinder is leaking from the rear seal then usually the Brake booster is bad as well and either cause a huge vaccum leak or not work and give you a hard pedal.
long story short.... replace the master cylinder and Booster as a pair.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
In fact, it is leaking from the rear. Thats good advice and I will do just that. This brings me to another question. I have the giant booster that is an eye sore. Someone on this site installed a smaller booster that looker real nice. Can anyone advise? I would like to know what year/make and model booster and master to use for this set up.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Originally posted by 88grandmarq View PostFrom my experience, if the master cylinder is leaking from the rear seal then usually the Brake booster is bad as well and either cause a huge vaccum leak or not work and give you a hard pedal.
Will I be able to do what he did???Vehicle: 1965 Pontiac Catalina (fastback 2+2)
dunno, see what he did. I think Freshmeat also did a later model booster and MC setup. Not entirely sure whats involved. The newer ones are smaller diameter, but they are thicker so I'm not sure how less visible they are. Also, the lines are routed different, so you'll need to make up some new lines from the prop valve to the MC.86 Lincoln Town Car (Galactica).
