Searched and found outdated info.
Are there any updated benefits or issues with the steel-to-aluminum drive-shaft swap? (Yes, I know you have to change the flange.)
If you were to spend a fair amount of time at the 1/4 mile drag strip, which drive-shaft would you say is better? Will the aluminum hold up just as well as the steel?
All relevant info is appreciated.
