I have:
tie rod ends (all 4)
tie rod sleeves (2)
idler arm
pitman arm
rotors
pads
inner/outer bearings/seals/dust caps/a bucket of bearing grease
a bunch of dot 3
I do not have:
any experience replacing any of those things
however,
I replaced all of my suspension sofar myself with the exception of front coil springs. Did shocks and rear springs, and today I did my front sway bar end links and bushing. All of that stuff seemed pretty straightforward but the front end gubbins is all interconnected in such a way that I don't know where to start with it. I have the haynes book for my car so I've got it to fall back on if need be, I was hoping I'd be able to ask you lot for help as well. Where the hell do I start?!
What tools are needed? I need to get a grease gun because all of my MOOG parts have grease nipples. Is there a recommended kind of grease?
I have never done brakes myself, either, so any advice there would be appreciated. Don't write a novel because I know there are novels written on the subject on the board, just any tidbits that might help a n00b at brakes. irony, my last name is brake.
It also looks like I should really replace the rubber bump stop things. How many do I have?
I really hope none of this stuff is beyond me. I'll have to do it at some point since I'm gonna be schoolin' to be a mechanic..but doing it to my own car when I don't have the option of fucking it up like I would a vehicle in the classroom.
thanks all
tie rod sleeves (2)
idler arm
pitman arm
rotors
pads
a bunch of dot 3
I do not have:
however,
thanks all
