t5 manual trans?
    t5 manual trans?
    Hi!
    Not requiring details yet, not taking it seriously YET....
    But, is it possible?
    I'm NEVER going to learn to drive manual until I own one as a daily driver.
    And as my panther wagon is going to remain my fulltime daily driver for at least 2 years more...
    And as we learn to do manual transmissions next spring, most likely...
    Is it possible?
    Cut a hole in the floor for the shifter
    Obviously it can bolt up to a 302 because the fox bodies have them; does a t5 match up to the chassis and to the rest of the drivetrain?
    at least 2 cars here have it done. I believe it's Southern_Pride and Pesty351
      sweet! Southern_Pride and Pesty351, do you have photos of what the shifter looks like inside the car? Can it be done clean & professional?
        the hardest thing would be the pedal assembly/quadrant and the clutch cable/firewall adjuster.
        1994 MGM GS Montigua
        2002 Mustang GT Coupe
          You will need a fox body clutch pedal, aftermarket quadrant, and you need to relocate your cross-member but it is a fairly simple job.
            I've never worked on an f-150, so I don't know what it looks like, but have wondered about using a truck pedal assy? Has anyone investigated that?
              Ahem...
              I don't really mention it in the video, but you can see the interior view at 2:53 -3:15
              The shifter is made out of a brake pedal.
              If you've got a 79-89 the most tedious part is the pedal + brake booster work. The 90+ is easier because pedal assy is different, and there's more room for the clutch quadrant. The transmission went in like it was made for the car.
              Axle codes
              Open/Lock/Ratio #
              G / H / 2.26
              B / C / 2.47
              8 / M / 2.73
              7 / - / 3.07
              Y / Z / 3.08
              4 / D / 3.42
              F / R / 3.45
              5 / E / 3.27
              6 / W / 3.73
              2 / K / 3.55
              A / - / 3.63
              J / - / 3.85
                Can the '90 pedal + assy be swapped in?
                I've always been a stick guy, & would like to do this swap to the '87 CS. I have contemplated taking the TKO (1st gen) from the Capri & replacing it with a TKO 500 or 600 for it.....
                I would guess that would be the right time to do the rear disc & newer front brake upgrade since it appears that the booster would be done w\the tranny swap...
                  Freshmeat has a sticky regarding the swap.
                  As far as using a truck pedal assembly, I'd imagine it would prove difficult. Trucks have a taller firewall, which means the pedal assembly is longer, and may interfere with the firewall/ floor during operation. It could probably be made to work, but there are no promises.
                  I actually thought about buying and aftermarket Ansen style assembly, or going with a Tilton assembly and eliminating the power brakes.
                    You will need to use an aero brake booster. It bolts right up but is narrower to make room for the cable.
                      The truck pedal setup is a hydraulic clutch setup. You'll find that aside from the thing physically not fitting, and the t5 being a cable driven setup, that there is no room on the firewall for a clutch cylinder.
                      The 79-89 pedal assy isn't the problem. It's the shape of the firewall, and the space beneath the dash that is the problem. On a 90-91 you weld the tube for the clutch pedal on top of the assy, but on a 79-89 you drill a hole and route it through the middle.
                      As soon as you try to install it, you'll see the clutch quadrant hits at the top, and you'll need to cut a notch in a rib way up at the top of the firewall. I had to even take a punch and beat the top of the rib up just a tiny bit as well, but then I should have mounted my clutch pedal about 1/8" lower.
                      The brake booster comes from an aero vic/marquis WITHOUT ABS. Everywhere I went they kept trying to sell me the wrong brake booster. The easy way to tell, is to take a master cylinder with you, and make sure it will fit.
                      The abs version has the studs set farther apart, and the hole is too big.
                      You could upgrade the brakes, etc while you are at it, but there is no real reason to.
                      While you will need to swap out the brake booster, the master cylinder will still fit, and there is just enough length on the brake lines for it to work in it's new position. You don't even have to unhook the lines.
                      If it were me, I'd get the 5 speed project done, and finished out the way you want it, so you can be driving it while you save up for the brake+ suspension upgrade.
                      Axle codes
                      Open/Lock/Ratio #
                      G / H / 2.26
                      B / C / 2.47
                      8 / M / 2.73
                      7 / - / 3.07
                      Y / Z / 3.08
                      4 / D / 3.42
                      F / R / 3.45
                      5 / E / 3.27
                      6 / W / 3.73
                      2 / K / 3.55
                      A / - / 3.63
                      J / - / 3.85
                        Posted a link wrongity wrong...
                        here are some terrible pics of the brake pedal setup.
                        The clutch pedal is from the mustang assembly, but the brake pedal is the original one from a my car. I just cut it down to the same shape, so the mustang rubber pedal covers would fit.
                        side view
                        top view
                        pass side view... sorta.
                        The clutch quadrant is rotated 90 degrees to far clockwise. If it were in it's proper position you can see that it extends above the pedal assembly about 3/8"-1/2"
                        As for the firewall adjuster, I never could make mine work in the location I had to use. I just took the slack up at the transmission with cable clamps. It isn't an elegant solution, but it cost me all of 2$ and it works just fine.
                        Axle codes
                        Open/Lock/Ratio #
                        G / H / 2.26
                        B / C / 2.47
                        8 / M / 2.73
                        7 / - / 3.07
                        Y / Z / 3.08
                        4 / D / 3.42
                        F / R / 3.45
                        5 / E / 3.27
                        6 / W / 3.73
                        2 / K / 3.55
                        A / - / 3.63
                        J / - / 3.85
                          Sorry I don't have one. I'm afraid I break one. And I'm finally figuring out how to rebuild an aod as I'm tired of smoking them. Almost ripped all the teeth off the low gear clutches in the last one.
                          1989 Grand Marquis LS
