What year F 150 shock do I need for the CC 819 springs? I broke one of the my rear shocks. Ya I know look it up in the FAQ. I did and it really doesn't say anything about it.
Shocks
Shocks
89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays. -
unless there's a height difference from a stock car... I would think stock style shocks would be fine. Just get the model that has the stiffness to your liking. And after looking up those springs... I definitely think regular shocks would work fine. They look to be the same diameter as stock springs, so stock style shocks shouldn't be an issue. Why would you want F-150 shocks anyhow?
Originally posted by Glen View PostWhat year F 150 shock do I need for the CC 819 springs? I broke one of the my rear shocks. Ya I know look it up in the FAQ. I did and it really doesn't say anything about it.sigpic
Originally posted by slymer View Postunless there's a height difference from a stock car... I would think stock style shocks would be fine. Just get the model that has the stiffness to your liking. And after looking up those springs... I definitely think regular shocks would work fine. They look to be the same diameter as stock springs, so stock style shocks shouldn't be an issue. Why would you want F-150 shocks anyhow?
weeell.... My car is stock height and the stock shocks are way to short. Though lifting the inside rear wheels on slight turns and being able to slide the back end out all the time was fun.
I don't know if the search works, but I had a good thread on this. The best bet is to actually measure the shocks with the springs installed, or at least with the current setup to see if the longer shocks are actually needed. Unbolt the lower shock mount and see how much droop there is. In theory the shock should be in the middle of the stroke at normal ride height.Builder/Owner of Badass Panther Wagons
99 f150 2wd
Thanks, the stock shocks are too short with the CC819 springs.Last edited by Glen; 04-03-2011, 12:14 AM.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
interesting. so I guess the springs do raise the ride height. makes me wonder what Good Samaritan is running on Herkamer for shocks all around.
The truck shocks are a good modification. I had them on my '90. The shocks were much beefier than car units anyway.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by Glen View PostThanks, the stock shocks are too short with the CC819 springs.sigpic
I went to mustang shocks as they are longer as well. I love my koni's but they are pricey.1989 Grand Marquis LS
Huh. I have the stock length KYB GR-2s with CC819s and I don't THINK I've had any problems, but I could be a moron.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Same here, stock motorcraft shocks with cc819's. No ill effects noted, no tire lifting (but I'm running whale cop springs up front (also with stock shocks), so its holding the car more level through turns so not enough lean to lift a rear wheel). And no, I'm not gentle with it.
Alex.Last edited by GM_Guy; 04-04-2011, 12:42 PM.
It pulled the rod all the out of the right shock. The truck shock it longer, but you have to change the lower shock mounting bolt or remove the sleeve in the shock. Which I found out after we had the old shocks off.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
