yeh had it dyno tuned for 5 hrs at alternative in michigan and she spit out some good hp and tq, only reving it up to 5600rpm on the cast pistons. ill get the dyno sheets up here soon. but yes tuned for everything in my sig. cam is .533 and .544 lift. heads are mildly ported and lots of other stuff not listed that i havnt got around to posting. nitrous will be activated with my 3000rpm setting on a window switch and full throttle switch which is at about the 20 ft mark to kick on. no nitrous i get decent take off traction with my 150 lb of sound shit in the trunk but a little spin on 1st shift.
ok so my rear end is good then, and driveshaft will hold 450 hp and the tranny? correct. and i might put in some better ujoints than my stockers. and i doubt the 275bfg's will do the job so slicks should be ok?
thanks, andy
thanks, andy
