They gave ya an 84 and down column I believe.
Steering Coulmb stupid
The only differance between the steering wheels is the conector in the wheel for the cruse. Newer wheel (brown one) is jumper wires from the connector to the horn in the center pad. The old wheel (blue one) could be used on a newer modle and you would have horn in the turn signal and wheel. Cruse switches in the wheels could be swapped. Think the center pad could also be swapped but haven checked yet. The turn signal switches could also be swapped.Scars are tatoos of the fearless
Should mention the newer steering wheel is held on by a bolt the older ones are held on by a nut. To remove old one remove the nut and use a puller to remove the wheel. The newer bolted style loosen the nut so there is about 1/8 to 3/16 between the nut and wheel do not remove the bolt. Install the puller and push against the bolt (sometimes the bolt might turn with the puller might need to hold the bolt with a wrench). Tighten the puller untill the wheel pops up. Remove bolt and wheel.Scars are tatoos of the fearless
There is adifferance in these connectors possibly due to EFI vs carb or CFI. The older one has a single round connector the newer 2 rectangular plugs. It can be pulled out through the front of the plate. The sleeve on the wires clips to a bracket to hold it in place.
Had to swap it out to have proper connectors for Creamy.
The spring on the front can also be poped off and the plate unsrewed and change out which I because the white clip on the plate that holds the trim collar behind the wheel was crooked fixed that and reinstalled. Wierd thing the newer spring was a tad stronger and wound the opposite direction (used the newer spring). No big deal, plates are the same.Last edited by turbo2256b; 11-11-2012, 09:39 PM.Scars are tatoos of the fearless
Originally posted by turbo2256b View PostHere is what was sent. It an earlyier version with the horn ativated by pushing in on the turn signal stalk. Think Ford started this on the 79 Mustangs known as the Europe style wiper, turn signal switches
[ATTACH=CONFIG]34230[/ATTACH]
[ATTACH=CONFIG]34231[/ATTACH]
Originally posted by t65neon5 View Postactually the 78 fairmont and fiesta had this also.....Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Guess the yard they pulled the column at didnt know how to at the seals to the floor pan at the end of the shaft and cut the plastic shield over the rubber boot at the floor boad / firewall. 2 screws attach it on the interior side then the rest are on the engine bay side. Actually already did the swap in these picsScars are tatoos of the fearless
To remove the plastic shield a screew driver or such and a small hammer is all thats needed. Theree are some clips on the shaft carefull not to dammage them. Should be reinstalled upon reassembly. In this case I removed the bracket attached to the lower mounting bracket of the steering column. There are some seals in the rubber boot that can be snapped in and out. Also a bushing in the bracket. Inspected them for the ones that looked best greased them a tad and put it all back togeather.Scars are tatoos of the fearless
How about you guys with steering wheels that are a bit rocky. It might have nothing to do with bearings in the tilt. Under the tilt hsg are a couple bolts that attach the hsg to the column. In my case the screws holding the switch in place were loosee too. I removed the bolts under the switch in the new column and applied some blue loctite and tightened them down.Scars are tatoos of the fearless
