I apolagize if this has been covered before, but is there a way i could do a front end alignment myself? I understand that if it can be done, it would be far from perfect, but anything would be better than how it is now. If its possible, could someone tell me how to do it?
My car used to drive straight as an arrow, then one day I replaced the outer tie rod ends, and front shocks. I measured the amount of threads showing on the tie rod end, then did the same with the new ones. Apparently I did something wrong though, because ever since then my alignment has been off. its weird though, the tires dont point inward or outward, they just are closer at the the top than the bottom. I dont exactly know if the camber or caster?
Maybe someone could help?
