What Is It?
What Is It?
"Cars are for driving - PERIOD! I DON'T TEXT, TWEET OR TWERK!!!!" -
Its purpose is to dampen the exhaust so it doesn't drone. I dont know exactly what Ford calls it though.86 Lincoln Town Car (Galactica).
How did I know you or Scotty would be first to respond? THANKS!! Bobby
Hi
Ford got cheap on some model year Town Cars and only fitted one on the right side, then issued a service bulletin to fit another to the left side after numerous complaints of droning in the exhuast.
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
I have a set of those off of something...Always forget to put it on when the exhaust comes apart of the car is up in the air though. Doubt it is necessary even to bother.~David~
it's a weight balancer for the single exhaust setups.
didn't say it was needed... just what it was used for.
yeah, i had the same on mine when i had the single exhaust, just a weight. i left it off when i installed the h pipe2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.
Its not needed, but it makes things quieter at certain engine speeds. Probably would't notice it much with aftermarket exhaust parts though.86 Lincoln Town Car (Galactica).
Originally posted by slymer View Postit's a weight balancer for the single exhaust setups.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
If I remember correctly, the 93 sport also had them. I wonder if they would reduce the low rpm drone.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
it would help probably. thats what they were there for. I need to dig up a set to fit a Mark VII H pipe. I don't remember if the Mark has them, but I know the Towncar does not and its got drone issues. The Mark does too actually, and I'd like them to go away. Its a Lincoln, it should be like driving down the road in a tomb with a couch in it.86 Lincoln Town Car (Galactica).
