Originally posted by Piece-it pete
View Post
I goofed and bought the cop kit (4.3153), and had to modify two bushings to make it work. That was a pain, don't recommend it if you can be smart and buy the right kit to start with.
The kit includes the eight front control arm bushings, new spring seats, and some special grease for the bushings. I bought some extra grease and ended up actually using a tube or so.
If you've read this far, you'll already know to replace the locknuts on the upper control arm shafts (I want to say about a buck each?), and to thoroughly clean the washers and shells.
Since you'll have your front suspension completely disassembled, this is a convenient time to put on new balljoints, tie rods, pitman arm, and idler arm, provided you have the money for all that.
Also, come to think of it, if you want to do your swaybar bushings and endlinks at the same time (and if your endlinks are like mine, they'll break when removed anyway), you'll need to measure your swaybar diameter and order those separately.
Only problem? After buying all those extra parts, it's no longer a 55 dollar project. :p
