I'm getting ready to cut and install my 00 P71 front springs tomorrow. How much should I cut off them? Any of you guys successfully cut a pair of these? I'm thinking of taking 3/4-1 full coil off.
Anybody Cut P71 Springs for their Big Brake Swap on a Box Panther??
87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,Tags: None
hope you have your fender lips rolled
yeah, not advised. I had to replace a fender, the trim, and a tire after trying to lower the front end of the car a bit using box police springs. It smashes the hell out of the wheel well if you have to turn and hit a bump at the same time. As long as you never have to do that, it works. Driveways are basically off-limits.86 Lincoln Town Car (Galactica).
I'm actually thinking to put PI springs on my 93 to raise it up a bit since the tires get so friggen close to the fenders. I'll probably add load leveler assist bags to the rear springs eventually too.
Well, this sucks to hear, but I can't imagine that an inch drop will cause issues. The thing sits monster truck high in front. I plan to cut off a 1/2 coil to start. Most the 88 towncars I've seen sit slammed in the front as if ford used a different spring beginning in 88, only explanation I can think of and wouldn't surprise me.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
After several sets of springs, I ended up with 1986 Towncar replacements. It sits where it belongs. Whale GMQ springs put it at donk height, 80s police car springs was lowrider smash things up. The stock old springs sit low because they're usually worn out. New stock replacements are probably an inch higher than what you're taking out, assuming you are removing original springs.
I've just given in to the fact that I don't understand spring rates and all that enough to know how to calculate what the free height needs to be in order to give a desired ride height. I'll just let the people that designed the car do that part for me.86 Lincoln Town Car (Galactica).
Yeah, I feel ya Gadget. Thing is that my car appears to have about 10 inches of travel in the fenderwell. I understand that if I am at a full turn and all of a sudden my suspension compresses that I will be pushing tire into the fender. I've owned a slammed mustang cobra and never had an issue like this. I can't believe this would be any more likely to happen in this Town Car.
Originally posted by gadget73 View PostAfter several sets of springs, I ended up with 1986 Towncar replacements. It sits where it belongs. Whale GMQ springs put it at donk height, 80s police car springs was lowrider smash things up. The stock old springs sit low because they're usually worn out. New stock replacements are probably an inch higher than what you're taking out, assuming you are removing original springs.
I've just given in to the fact that I don't understand spring rates and all that enough to know how to calculate what the free height needs to be in order to give a desired ride height. I'll just let the people that designed the car do that part for me.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
yea, gadgets car is why i do not think it is a good idea, too high it looks stupid, too low and it wrecks things.
What kind of springs are you running on your rig?
Originally posted by Lincolnmania View Postyea, gadgets car is why i do not think it is a good idea, too high it looks stupid, too low and it wrecks things.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
What springs does MrLtd run?
i'm running my original front springs.
town car sheetmetal is different and there is more weight on the front end, so what works on a vic or a grand marquis does not work on a box towny. you can install whatever you want, i would just hate to see you lose a tire or a fender or both entering someones driveway.
Originally posted by 87stars_stripes View PostYeah, I feel ya Gadget. Thing is that my car appears to have about 10 inches of travel in the fenderwell. I understand that if I am at a full turn and all of a sudden my suspension compresses that I will be pushing tire into the fender. I've owned a slammed mustang cobra and never had an issue like this. I can't believe this would be any more likely to happen in this Town Car.
Alex.
Originally posted by Lincolnmania View Posti'm running my original front springs.
Well, I cut exactly 9 inches of coil (approx. 1/2 coil) out of the spring and they ride fine. No issues so far.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
after driving around for a while (some say 250 miles... some say 500) they should be fully seated and your ride height assured at that point.
pics!
