I just went to check my brake booster, and I noticed every time I pressed the brakes, there was a squeak. I eventually figured out that it's coming from the rear left wheel. It's parked, and it squeaks louder the faster I press the pedal. It's pretty loud, too.
I also get brake squeal when driving, but only at light pressure. Once I press the pedal harder, it stops.
I'm guessing it's time to rebuild the brakes again. The last time I had the brakes done was when I first got it 3 years ago. From what I read, drums don't last nearly as long as discs, so that might be the problem.
Am I on the right track? If so, how do I know if I have 10 or 11 inch drums?
EDIT: Nevermind, found the brake info thread. They're 10 inch.
