I ask because I am planning to go back to stock gears in my '95 Mustang and would like to use the 3.73s that are currently in there in the Mercury. It's likely going to end up with an HO swap, or possibly a GT-40P headed motor next year.
Would 3.73:1 be too much gear for an HO-swapped panther?
—John
1985 Ford F-150 XLT Lariat
1966 Mustang coupe (restoration in-progress)Tags: None
no.
i have 3.73's in the LSS.
Beautiful. Thanks for the input.—John
+1 3.73 are fine. You'll want the 7 tooth transmission output shaft from the Mustang or you'll need a 23 tooth speedo gear to get the speedo to be correct or a VSS signal modifier module to step down the signal.
Scott, remember he's in TX - they laugh at 75 mph speed limits there...The ones who accomplish true greatness, are the foolish who keep pressing onward.
yes... yes we do...
I actually tend to set my cruise control at about 78.—John
Originally posted by Elias View PostI have some 3:55 if u want them for cheap dont need them. They came with a track lock I bought.—John
Oddly enough, I'll take my chances with US-made used factory gears rather than new Chinese junk. And I hate to break to you, unless your new gears are NOS Ford parts, you are getting Chinese shit (there is only one aftermarket manufacturer who still machines gears in house, forgot who that is tho, but their facility is in the Chicago area). Even Ford actually dropped the ball with the whale Panthers, they have shit gears as well.
So yeah, if I have a choice I'd do NOS box- to aero-era Ford parts, or used Ford parts from the same period, not touching '99-up Ford gears new or used, or anything aftermarket.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Well, that's just dandy. I'm looking to go back to stock in the Mustang, which means 3.08s. I'll have to look around for a NOS or a good used set, then.—John
trade the ones out of the Mercury.86 Lincoln Town Car (Galactica).
I was literally about to make a post about this. I just got done with my HO conversion on my '86 town car, and with the GT cam, it's a dog down low in the RPM's. Aside from the trans go shift kit, I was going to try and get a set of 3.55's from a p71. Mine also has the 2.73 gears since my TC is a base model.
My main concern is that I'll end up turning too many RPM on the highway. I have 3.73s in the Mustang with 26.1" rear tires, a .67 5th gear. I turn around 2500 around 75. It's just too much in the Mustang. Might feel different in a big car like the Mercury, though. Probably help with passing on the highway. A 3.55 gear set might be a good compromise and wouldn't require that I wait until I get around to swapping the gears out of the Mustang.—John
