my steering shaft u-joint only has play up and down, but has no play side to side, should i be concered?
its the rotational play thats more important. The up/down play is quite possibly where the shafts fit together. Its a double flat thing with a cross bolt, and it will have some play 90 degrees to the bolt. With the wheel straight the bolt should be horizontal so the play will be vertical.86 Lincoln Town Car (Galactica).
