This morning on the way to work, I noticed my brakes felt odd. At first I noticed the rear seem to make a click/clink on release, then I noticed the fronts seem to grab pretty quick and it felt like the right front. Any ideas before I head home tonight?
Braking question
Braking question
Mercury Owners Group member
Save The Whales, Restore an Old Station Wagon!!Tags: None
Which car is it....4 wheel disc or rear drum?President He Man Woman Haters Club
Life should not be a journey to the grave with the intention of arriving safely in a pretty & well preserved body,But rather skid in broadside,Thourghly used up totaly worn out & loudly proclaiming...WOW WHAT A RIDE!!!
http://www.myspace.com/dabearsplace
Originally posted by DatdambearWhich car is it....4 wheel disc or rear drum?
Originally posted by Blaze86VicRear drums. The clicking could be thea uto adjusters finly catching up. It's not to uncommon for the calipers to grad at different rates.
Could one of the calipers need a bit of lube or cleaning?2000 Grand Marquis LS
Yep slides dirty up ...cause what your talking about...Clean them up real good...when you do make sure the caliper piston returns easy...if stiff or will not then you know you have other issues....also inspect the brake lines...cracks kinks ....they have been known to colapse internaly causing caliper issues.The rear drums sounds like adjusters...President He Man Woman Haters Club
new development..
When I headed out for lunch I had no front brakes. Checked the fluid and they were both half full. When I took off after checking, I had brakes again.
:cuss:2000 Grand Marquis LS
Sounds like the sliders are rusted up or the calipers are giving up on you. Pull the sliders and run them on a wire wheel, then put some superlube or the stuff made for disk brake hardware on there and see if you're ok again. I'd also seriously consider a flush on the brake fluid if its not been done already. It might not be a bad idea to to do front hoses and calipers along with a brake fluid flush to get it all fresh again. Calipers are fairly cheap, so are hoses. Probably you can do both sides for under $100 if the pads are still OK. Maybe you're a bit over $100 if it needs pads.86 Lincoln Town Car (Galactica).
They seemed OK this morning, so I am gonna look them over good this weekend. Pads are good, so that's not an issue.The fluid does look awfully dark so I will flush them and see if that improves the problem, if not calipers and hoses next.
Is there any difference in quality between makers of calipers? Some at AutoZone are like 20 bucks with some at advance up to 60 bucks. I plan to have this long term and tow a trailer so I don't wanna go cheap.
ThanksLast edited by 85MercPark; 04-11-2006, 08:13 AM.2000 Grand Marquis LS
so would you recommend police calipers?
I think I have the OE pads on there now
For the cost I will get new ones when I change calipers2000 Grand Marquis LS
Thanks
so I will get police calipers and police pads. Wagner Thermo-Quiet or Bendix pads...
sounds like a plan.
How's Europe treating ya?2000 Grand Marquis LS
