Ok think home solar panels, Now envision a tiny solar panel on your dashboard with a cable back to the battery to keep the aforementioned trickle charged. So does such a device exist??
Does it exist, solar panel to trickle charge battery?????
Any small 12 volt panel that plugs into an always active power port or lighter socket should be great. I used them for decades just to keep up the charge on my 4 battery boat which was moored so had no dock power.
this is just some rando amazon panel
https://www.amazon.com/Sunway-Solar-...s%2C123&sr=8-803 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
- Likes 1
All depends upon if your electrical system is working correctly or not. If it is (and you don't really need the panel), then they may be fine. If you have any medium or large "draws" then forget it!What I Own: 1993 Mercury Grand Marquis GS
Correct a small panel will not compensate for an abnormal draw. All it will do is slow the discharge in a good but largely unused system.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I believe some VWs in the early 2000s came with these as delivered? I remember walking a VW lot in the 2003-2004 time frame (my Mom bought a Beetle then), and seeing these suction cupped on the windshield. Maybe it was just for use while the cars sat on the lot.
https://www.ebay.com/itm/195257722136
On the boat i never unplugged the unit even when the engines were running.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
