I haven’t given it much throttle yet but I’ll try next time it starts. And I’ll check for codes real quick.
1989 Grand Marquis ECM removal
can you keep it running with the throttle? If the IAC is sticky it might open too far, then slam shut and stall. If it can be kept running with some throttle, it sounds like things are basically working and its an idle control issue.
aftermarket IAC can also do stupid things, but most of the time you can just flush out the originals with some brakleen or carb cleaner and have them work properly again.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postcan you keep it running with the throttle? If the IAC is sticky it might open too far, then slam shut and stall. If it can be kept running with some throttle, it sounds like things are basically working and its an idle control issue.
aftermarket IAC can also do stupid things, but most of the time you can just flush out the originals with some brakleen or carb cleaner and have them work properly again.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View Post
If you are going to spray the IAC (I'd get a new one and OEM) make certain to have the motor half facing up as you do NOT want any chemicals seeping into it!
Edit: cleaned IAC and started it. I gave it some throttle but it seems like nothing changed when I did, it was stalling from the start. Checked codes and still 23 and 63. Also got a code that was just “1” no follow up. Don’t know what that is, since “11” is the clear code.Last edited by monotonorobo; 11-17-2023, 09:29 PM.
Have you back-probed the TPS to measure closed voltage? I think the acceptable value is like 0.6v-1.2v, but preferably setting it around the 0.9v range is a great medium for closed throttle, and you want to ensure at wide open it's around a minimum of 4.1-4.3v IIRC.
Codes 23 and 63 imply an improperly adjusted/failed TPS. Obviously check first before replacing the sensor.
- Likes 1
they aren't really adjustable but if its installed wrong it won't read in range. It doesn't go straight on, you have to put it on there so the tabs on the sensor engage on the tang on top of the throttle blade, and you rotate it slightly to line up the screws. If its just put straight on, the sensor will not engage with the throttle blade and won't read. The voltmeter will tell you, it won't be in range and the voltage will not change.86 Lincoln Town Car (Galactica).
Originally posted by Kodachrome Wolf View PostHave you back-probed the TPS to measure closed voltage? I think the acceptable value is like 0.6v-1.2v, but preferably setting it around the 0.9v range is a great medium for closed throttle, and you want to ensure at wide open it's around a minimum of 4.1-4.3v IIRC.
just open the throttle by moving the lever under the throttle body. verify the voltage goes up when you do.86 Lincoln Town Car (Galactica).
- Likes 1
Originally posted by gadget73 View Postjust open the throttle by moving the lever under the throttle body. verify the voltage goes up when you do.
Edit: Forgot to say code 63 is still there.Last edited by monotonorobo; 11-19-2023, 02:36 PM.
Got it down to .9 volts and checked MAP. All seems well in that regard. And pulled some plugs and it seems one is barely firing. The first one is Cylinder #1, second is #2, third #5, fourth is #6. The fuel is rich because I smell it whenever I crank it. There’s also black smoke coming out the exhaust. Someone else I asked thinks I have bad injectors.
+1... gas in the oil would indicate stupid rich mix and injectors stuck open.
- Likes 1
