I've had this problem for a little while now...getting annoyed by it.
when I'm between like 600-1500 rpm, all of my lights pulse with the engine rpm...once it gets above 1500rpm, its pretty solid.
when it did this before, it was the fuse for my fog lamps...and that got disconnected when I replaced the red cable for the battery...just havent hooked it up yet.
is it maybe a bad regulator in the alternator or something?
it has done this on and off since I bought the car in Nov. 04...I have gone thru....2 alternators...I'm on my 3rd.
still has the same battery in it that it did when I bought it...an Interstate Battery.
I havent had any trouble with it...other than the corroded cable...and sometimes I've left my headlamps on and drained it..its happened a few times.
any ideas?
the only thing I'm thinking of is doing the "3G Conversion" that Bobert did to his old Merk...sure did keep the lights bright and smooth after that.
any ideas?
