Carb issues
    Carb issues
    Well i rebuilt my carb and i also put a new windo motor in but when i went go reinstall it i forgot where all the hoes went....So i need a pic of how it goes. Please
    there should be a vacuum routing diagram on your fan shroud if it's still there after 25 years
      ok ill check
        NO hope i dont know how to read that thing.
          I'll try to snap a couple pix of my carb tomorrow if I get a chance and post 'em up for you so you can go off of that. I don't remember there being THAT many vacuum lines to it, though...like maybe three or so?
            Yea i think....but one of them is puffing out white smoke and theres gas coming out the top of the carb where a hose is spose to be hooked 2. And now it sounds like its only hittin off 7 cylinders so what do i do about that new spark plugs and wires and i new distributor?
              Can you post pictures of this thing that gas is coming out of where there's supposed to be a line attached?
                Ohh yea and the door from that 85 mgm fits but its off a lil bit. should i go take the hinges of the 85 and use them 2.
                  Yea ill go take one now. NVM the digital camera is know where to be found.
                    Probably one is a PCV line, it should go to the large fitting on the bottom of the carb. There should be another large fitting that the hose from the vacuum tree goes to, and a small one for the vacuum advance. Most of the fittings should match the sizes of hose available. If you've got fuel pouring out of the side of the carb, it sounds like the float level wasn't set properly.
                      Ima just buy me a new carb.Can sombody find me a new one on ebay.
                        So i guess nobody found me one. I dont know what to look for.
                          You'd want to search for a Variable Venturi carb, but before you give up on this one, I'd go through it again and make sure that you've got everything adjusted according to the instructions.
                          You could buy a remanufactured carb from eBay or something, but "remanufactured" does not necessarily mean it's adjusted correctly, so you may not be any further ahead. If you're somewhat mechanically inclined, you could also swap on a regular 2 bbl carb (Motorcraft 2150), but the car probably won't perform quite as well or get the same gas mileage it does now.
                            its got a 2bbl on it now
                              It's not a Variable Venturi?
