Automatic Headlight Wiring
    Originally posted by Dereck View Post
    Hi 86VickyLX
    Try This Resistor.
    They are only little fellas, I soldered wires onto each end, then encased it in heat shrink folded the wires over and put another layer of heatshrink over it to git it some protection.
    The value of the resistor is what gives you the delayed exit time, the higher the resistance the longer the delayed exit lights on time, I found 60Kohms gave about 30 seconds of delayed exit, if you want longer up the resistance.
    Regards
    Dereck
    wow that's not what I expected. I expected it to look a little different. Cool.
      I got the resistor and I will try to get the relay sometime this week.
      Dereck I was wondering what the color codes on the headlight harness is.
      Like I saw the brown wire for the parking lights and that's the only one I could see.
        http://www.grainger.com/Grainger/items/1EGF4 I found a relay, I think this one should work. It's double pole, double throw relay. And, their warehouse (Grainger) is nearby so I can go to it when I get the money together. I can use this one right Dereck?
          Hi 86VickyLX
          Looks like you are on the case
          Regards
          Dereck
          President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
            Hi 86VickyLX
            Regards
            Dereck
            Thanks mang. I ordered it and it should be here Tuesday, or somewhere around there. I also decided to get the base to make the wiring easier.
            Also Dereck, I was wondering what the color codes on the headlight wiring harness is.
              brown is the parking lights
              red/black is low beam
              light green/black is high beam
              the headlamp power wire between the light switch and the MF switch is a red/yellow
                Thank you. Now I'm all set. When I get the relay I should be good.
                  Hi 86VickyLX
                  You do not need to splice into the hi/lo beam wires you only need to splice into the parking lights and headlights wires from the back of the main light switch.
                  You need the following wires from the main light switch;
                  Brown = parking lights
                  Red/Yellow = headlights (to multi-function switch)
                  Tan/White = fused supply for parking ligts
                  Black/Orange = fused supply for headlights
                  Regards
                  Dereck
                    Hi 86VickyLX
                    Regards
                    Dereck
                    oh ok thanks so much
                      Big question!!!!! Do I need a switch at all? Like for example the push button switch that connects to the Purple/Orange wire on the Day/Night sensor harness. Do I need a switch at all? If not, what do I do with that wire?
                        Other than that, everything else is set up and ready to go.
                          Hi 86VivkyLX
                          No you do not need a switch just ground the Purple/Orange wire from the day/night sensor and the autolamps will be always on.
                          Regards
                          Dereck
                            Hi 86VivkyLX
                            Regards
                            Dereck
                            On as in when they are supposed to be on right?
                              Hi 86VickyLX
                              Perhaps I should have said "The autolamp system will always be active whenever you are driving the car".
                              Regards
                              Dereck
                                Hi 86VickyLX
                                Regards
                                Dereck
                                oh, ok. Gonna get a switch
