My heater core sprung a leak, my heat smells like anti-freeze and I can see it dripping on the floor. Can I get to it by pulling the glove box out or do I have to pull the whole dash out?
Heater core replacement.
you jus have to pull the glove box, undo the main dash frame bolt on the pass side so the dash is flexible and undo the bolts from the engine compartment that hold the box in place, then the box should wiggle out then its all straight forward from there
Originally posted by MeanVic84 View PostMy heater core sprung a leak, my heat smells like anti-freeze and I can see it dripping on the floor. Can I get to it by pulling the glove box out or do I have to pull the whole dash out?
its much easier on a panther, especially lincolns
