There are a lot of hills around here, and when I'm going up them, it takes a long time for my cruise to catch on, then when it does, it doesn't seem to quite get me back up to speed. I'll drop from 70 down to almost 60 before it decides that it's got some work to do. Is this just old style cruise, or is it not working right.
Cruise control sucks
Use a vacuum pump and see if it holds.86 Lincoln Town Car (Galactica).
the cruise control cable needs to be adjusted......it's possibly too loose, and cannot pull the throttle lever enough to hold speed
Originally posted by Lincolnmania View Postthe cruise control cable needs to be adjusted......it's possibly too loose, and cannot pull the throttle lever enough to hold speed
I'm thinking along the lines of vacuum loss as he's going uphill. Cruise control was not made for hills, but interstate/highway driving. As he's going uphill, the cruise is trying to catch up, calling for more throttle, and, if I'm not mistaking, causing a loss of vacuum low enough to kick out the servo. Before MORRIS goes, and starts tearing everything apart, he should get it out on the open road, and make sure the cruise is actually malfunctioning first. Sorry Morris, I wasn't referring you in the third person on purpose.
MIKE
