The Headlight doors on the mark VI used to close when the car was running and for about 3 mins after I shut the car off they would stay closed. But today I went to the car wash with it, and they where fine, then after I got the car cleand and wen't to pull out and the auto lamps came on since it was a bit dark in the car wash. Ever since then they won't close at all now, Any ideas?
Headlight doors wont close
Originally posted by Grand_Marquis_LSS View PostThe Headlight doors on the mark VI used to close when the car was running and for about 3 mins after I shut the car off they would stay closed. But today I went to the car wash with it, and they where fine, then after I got the car cleand and wen't to pull out and the auto lamps came on since it was a bit dark in the car wash. Ever since then they won't close at all now, Any ideas?
The headlight switch has a vacuum port on it. If that failed, or if the vacuum line to the front cracked they won't shut. They ought to stay closed for a few days, so there was definitely a leak already. trace out the vacuum hoses from the headlamp doors and you'll probably find the problem.86 Lincoln Town Car (Galactica).
Ok got them to close again, Tap'd on the dash around the headlight switch and and i heard the thing make that hiss noise and the went down, must have been stuck.. I am going to look into where the leak is to so they stay down when the car is off
1980 Lincoln Continental Mark VI Signature Series
351 4 bbl, AOD, 3.08 open
duel exhaust with cherry bombs
