What is the difference between a wedge, 1w high power, or a 5 LED refractor wedge? Which works best for dash lighting? I want to replace the 194 bulbs with LED's.
LED Lights
LED Lights
89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.Tags: None
**My experience with refractor bulbs has not been good. They've all started dying out on me after a while - One small LED at a time, and they'd usually flicker dimly for a week or so first. I've had single bulb ("bullet style" directional ones) LEDs in my instrument cluster and 8 of 8 are still kicking. After a couple of months (twice), there would be 1 or 2 perfect bulbs (as in, all 5 LEDs on the bulb as bright as when I first put them in) left functional out of the 8 in my instrument cluster.
**This could be because:
- i bought cheap shit bulbs
- voltage going to my cluster and aftermarket gauges was too great for the little guys to handle
- the bulbs i got were a "bad batch" - i have heard of this happening
It should be known that nobody else on here has spoken of similar problems. At all, ever.
I have 5-way refractors still in the courtesy lights and in my glove box - All fine, but they're not getting constant 12v+ like the cluster.
I honestly think you would be fine buying the 5-way bulbs - Most everyone here likes them more than the directional ones.sigpic
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
Refractors will give more light and more evenly, one ways are very direct. You should use the refractors for your dash lighting."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
OK, thanks89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
I have had the 5 ways with the colored bases flicker and crap out a lot. I think it's because the LEDs have resistors set for 12v, and the alternator charges at 13.9. It goes away when i turn the dimmer all the way down, although the lights don't dim appreciably.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 91waggin View PostI have had the 5 ways with the colored bases flicker and crap out a lot. I think it's because the LEDs have resistors set for 12v, and the alternator charges at 13.9. It goes away when i turn the dimmer all the way down, although the lights don't dim appreciably.
this is kind of awesome to read. my car isn't actually an LED hungry version of christine.sigpic
I've had several different colors and types of the 5 way "refractor" bulbs fail, mostly the white ones but I have had a few blues and some reds die as well. I wish there was a way to find a reputable LED manufacturer that doesn't make a shit product.
All of my bad ones came from eBay; buyer beware.sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
3+ years ago they were still made with great quality. Still running the same led bulbs since that long ago~David~
