You know above the radio, the unit where the lower dial chooses off, max a/c, normal a/c, vent, etc.,
And the upper dial goes from cool to hot?
Well for some time now, the upper dial has been very hard to move.
Something's off with it; if you just push on it it wants to cut into the plastic face and bind. The only way to move it is to grip it powerfully between thumb and two forefingers to keep it perpendicular, and then force it along so it doesn't cut into the faceplate.
Has anyone else had this issue?
What is the fix?
Does the faceplate come off easily; maybe the steel arm is broken...?? I'm really not sure.
My father had said that when he owned a car with an analog control like that, it also tended to have the same issue when it got older.
thanks!
-Bernard
What is the fix?
thanks!
-Bernard
