loose 3g stator connection
    the 3G I've got in my car is getting a new Motorcraft wiring harness, I just went to install it and noticed that the white/black wire running to the plastic bit that clips onto the stator connection is slightly loose - about a mm or 2 mm of play in and out.
    What problems do you think this could cause, if any? The alternator is running and charging just fine at over 13v (reason for replacing the harness is that I have a flickering battery light that seems to go away when I fuck with the green/red wire right at the harness.) No drops in voltage whatsoever when the light is flickering.
    Since the stator has got to do with the operation of the alternator and the green wire is the one running to the bulb, do you think the loose stator connection could cause the flickering battery light?
    If the connection is loose, it would explain the light flickering.
      the plastic bump/protrusion holding the stator "harness" on is chipped! that's what is allowing for the play..pushed it on all the way and zip tied the bastard so it can't move at all..all I can really think of other than buying a new alternator because of a little plastic chip, and I ain't about to do that.
        You can use a little pin to remove the plastic cover off the wire and carefully squeeze the spade connector so it sits tighter on the alternator.
