Hi all Im the proud owner of an 89 Grand Marq and Ive replaced my turn signal stalk 3 times now with no difference in performance. the hazzard will work fine, so will the high beam switch, it will click off from a turn just NO signal when i try to use my turn signals.It wouldnt be a wiring issue would it cuz then my hazzards wouldnt function fully right?? Any help will be GREATLY appreciated
89Grand Marq turn signal issues
Try changing the blinker stat. There are seperate ones for hazards and 4 ways. I think you want the one visible in the fuse box under the column.86 Lincoln Town Car (Galactica).
Hazards and directionals use separate flashers. The directional flasher is the easily accessible one within the stock understeering column fuse box.~David~
