This caught me off guard! Last thursday I drove out for my lunchbreak and got a burger. I get in my car to leave, crank it, and NOTHING.
More specifically,
all the dash lights are on as they should be. So the car is "on," and the battery is quite fine.
It's not like I hear the starter trying to crank over the engine and failing, also a sign of, weak battery, failing starter, or corroded cables between the two.
Just, nothing. I try to crank it a dozen times.
I need to get back to work!
So I pop the hood, find some scissors I had laying in the car, get out and jump across the starter solenoid with success.
After I park the car back at my job, I try again... car starts right up.
Started right up several more times after that, too.
Never happened before,
and hasn't happened since.
Just one time, trying to turn the key all the way a number of times in a row.
I guess, loose connection either in or from the ignition cylinder (and anywhere between the ignition and where the fusible link goes to the starter solenoid, whatever harnesses are in between), or an intermittently failing starter solenoid (which is really just a heavy duty relay, isn't it?)?
Which is most likely? Without a permanent fault, since it's working again now, how do I even begin to find out what had been the problem? (or maybe I can't, and have to wait for it to act up again).
Of course, our old-fashioned fender-mounted starter solenoids do mean that even if this happens again, it's never going to strand me! As long as I have scissors or a wrench or something conductive in the car
More specifically,
