Hello, I'm new to this forum but have been reading through it for awhile now. After awhile of searching for a reasonably priced 86-89 Town Car I finally just decided to take an old 85 Crown Vic. I was against having it at first because its CFI and I have heard only bad things about that setup. But other than a few minor problems, this car drives great and is almost fully loaded. I just have a few questions to ask you guys if that's ok.
1) The car mostly only starts when I give it just a little bit of gas. It idles fine and I checked the fuel pressure and its ok. I was thinking maybe this could be the TPS going bad and I was wondering how to go about replacing that.
2) The car does have some minor rust spots, mostly on the rear drivers door, which I'll fix shortly, but the main problem with its appearance is the vinyl roof is completely shot, its the worst I've ever seen. I'm thinking of making it a slicktop since it seems that would be cheaper than redoing the vinyl. Would this be an expensive job?
3) The heat/ac only comes through the defrost vent, I now this means there is a vacuum leak, but where would be a good spot to inspect?
4) Would it be a good decision both performance and reliability wise to convert the CFI to an EFI setup? Currently I don't think I'll mess with it for awhile since the CFI is running ok, but for the future...
I'd really like to fix some cosmetic issues with this car and maybe do a few performance modifications as well. I'm also really wanting to add a tripminder and a police 140mph with a police gauge pod. Also some headlight relays with an option of keeping all four lights on at once. Please tell me any other modifications I should do. Thanks
