Courtesy Light...88 Lincoln Towny
    I got this in an effort to fix my passenger side, left rear light that will not turn on from the
    current switch in the bezel:
    I have the same issue on my drivers side control.....the switch does not turn on dome light
    I bought two of these....would this fix both issues?
    Another tid bit....I have no experience in doing this...any tips with how to connect the wiring
    would be appreciated.
    1979 Marquis creamy goodness
    The switch is not supposed to turn on the dome light , only the reading lights in the "C" pillar and only when the ignition is in the "on " position
    1988 Signature Series Town Car
      Cool, thanks for the info....but since my current switch does not do this...would it work if I were to replace it with what
      I bought?
      ......Im a newb....of course........... what is the "c" pillar?
        I bought?
        It may or may not be the problem , but it certainly would not hurt to try it. , it just plugs in when you take the bezel out of the door.
        The "c" pillar is where the back part of your roof slopes down to meet the car , they are referred to, front to back as "a" at the windshield "b" just after the front door , and "c"
          thanks again....any tips on how to connect the new switches?
          is it like "plug and play"?
            Yes , That switch you have pictured is plug and play
