I changed mine when I did some AC work recently when I replaced all hoses and the receiver/dryer. The dryer was all of $4(!) from RockAuto on closeout!
I assume this is 25 years of crud, but it could have been changed at some point.
Was going to put another blue one back in it, but went with red based on some advice I saw.
I have to say that doing this job on my box TC was NOT hard. Everything is right there for the most part, and no one should be afraid of doing this work. I rented a vacuum pump, manifold and gauge set, and orifice removal tool from AutoZone.
Of course, it is apparently somewhat probable that the orifice tube will break when removing it, and then you have to butcher the evaporator and install a little kit to fix it. So, caution. But mine worked fine.
You can see the new red orifice installed. That evaporator pipe is not as dirty as that picture makes it look...
