Tried to post this on CVN, but I have not received much of a response.
One of my fusible links attached to the starter solenoid blew earlier today. After I finished washing my car. I figured it was probably just damaged insulation and water generating a short, so I replaced the fusible link with another and it blew same as the last. I must have a short or some electrical damage somewhere.
The fusible link seems to feed power to my interior bits such as cabin lighting, headlights, hood light, running lights, and stereo.
The windows, AC blower motor, and brake lights still work fine.
Are there any obvious places to start looking? I'll attach pictures of the blown link. It seems to lead to a wire that's black/white or black/pink or black/orange or something -- I can't tell because it's such a light color.
I have a wiring diagram in my Haynes manual that doesn't seem to make sense. I found one online that seems to suggest the wire in question leads to most of the affected components. Also, I noticed that the new fusible link only blew once the vehicle was being started -- I tested it in accessory mode and it seemed fine for the few moments I had it going. I'm going to repair the connection again tomorrow after removing every fuse in my fuse box to see if I can narrow the culprit down. Any other advice?
