1986 Country Squire with Climate Control. Heater was set on VENT with the temp setting at HIGH. Had heat for about fifteen minutes while running errands, working beautifully. The car sat for about 20 minutes while I was shopping. Went to drive the car again and the heat was now barely warm, even though I had not changed the settings, I set the lever to HEAT and got nothing - no heat, no fan. Then to DEF and got weak blown air through the defroster ducts, but barely warm. The FAN switch now works only on LOW and MED, but now turns off at AUTO and HIGH settings.
Ideas???
Ideas???
