Aftermarket radio
You mean the original bracket that mounted to the back of the radio with the hook end? That doesn't come with a kit. The kits only give you the faceplate part.86 Lincoln Town Car (Galactica).
It’s been a long time but I think I rigged the factory bracket to work with the aftermarket radio. Another option is a block of styrofoam (AC Moore/Michaels) cut to fit.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
The stock radio had the rear bracket. You can probably make one pretty easy from some thin bar stock with pre-drilled holes in it. Like this stuff: https://www.homedepot.com/p/Everbilt...2037/204225755
honestly my car isn't using the stock bracket at all and it works. I do have a bracket here, I should see if it makes it sit better. The dash does rattle a bit, maybe some of it is the radio.86 Lincoln Town Car (Galactica).
Yea Im thinking of just making one or using styrofoam. I dont know what its supposed to look like but behind the bezel is just a gaping hole. The guy I bought the car from removed the stock radio and hvac panel and screwed a piece of flat aluminum in its place to mount a wot box.
Oh ok, Ill have to take a pic because I think Im missing more than that if there is more. The hole is a lot bigger than the radio, I just dont see that bracket working alone. Im thinking a single din mounting bracket with some styrofoam underneath or a custom bracket.
There should be a slot in the horizontal plate between the radio and climate controls that the bracket slots into and bolts to the back of the radio. With the radio installed, the bracket centers the rear of the radio according to where the panel slot is located.
Up front just requires an install kit like you posted earlier
It should be a sleeve that has four tabs that mimic what the factory radio would have.
You screw that to the dashboard in the factory radio’s screwholes then insert the new radio into that. Rig up a bracket or piece of foam to support the rear.
Check out Metra, they will have a kit that works2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
metra 99-5700 is one of the kits that works. you'll have to break off the mounting tabs that get in the way though.
