yeah thats not supposed to flap like that. and it definitely needs both bolts.
Belt alignment
offhand I don't know, but it is metric. Guessing its an M10, probably around 30-35mm long.86 Lincoln Town Car (Galactica).
re-install the missing support rod on the upper AC bracket. Maybe its tilted inward and causing the belt to not track correctly. Are all the other bolts in the brackets? Seems like something just isn't positioned correctly. The only time I had a belt hop was when I put it on the crank one groove off, and it ended up jumping at the compressor and ate the plug for the clutch.86 Lincoln Town Car (Galactica).
Thats pretty much what keeps happening. I thought about that, it seems to happen after it shifts and usually when I rev it out a little. I’ll have to look through the trunk as I don’t have that bracket in the car but there are some parts in the trunk.
And to top it off the low oil light came on today and by the time I got to work it seems to be knocking a little at idle. It seems to be coming from the front pullies but it could be the front rod bearing for all I know. No issues with the motor itself until now out of the blue.
The amber check level light or red engine light? If it’s check level, see how much oil is there. If it’s engine, it’ll probably live a while doing that at hot idle, but I’d address it.
My Cars:
that comes on when you're about a quart low. Not that big of a deal, just top it off. The red light of doom is the problem one.86 Lincoln Town Car (Galactica).
I topped it off on lunch and it seems the oil light and noise is gone but the belt is so loose now. Damn I’m pissed. I’m a little curious about the low oil though. I used a full 5 quarts recently and it doesn’t leak or burn oil at all. But yeah it was a little low.
Your engine bay is clean. And your battery cable end looks great.
Many 80’s 302’s burn oil to the tune of 1 quart per 1000-1500 miles give or take. Not enough to notice smoking but enough that it needs to be checked between oil changes. The check oil level light used to be a check windshield washer fluid light in the early boxes. I think Ford changed to light to cut down on replacement engines when people tried to go 7500 miles without checking the oil.1990 Country Squire - weekend cruiser, next project
Thanks man, I replaced the negative cable from the battery to the block not too long ago because it was starting to look bad. I’ve also tried to wipe everything down to get all the grime off but its not as clean as it looks in that pic lol.
Funny story, I had the same oil in it from the previous owner when I bought it in June ‘18 until a few months ago and it had sat for a while. Should I have changed it sooner oh yeah but I didn’t have time and it didn’t make any noises but the low oil light came on a few days before I changed it. I’ve probably put a few thousand miles on it so I believe what you’re saying. I have 4.10s so I can’t say exactly how many miles I’ve put on it though.
