Cruise control doesn’t work
    Ok so I couldn’t get to the dump valve without burning my hand on the light bulb under the dash lol so I pulled the hose off the servo and pulled vacuum and it held. Next I pulled the hose off the check valve and check the valve and it was also good. Then I pulled a line off the servo and tested the servo itself and sure enough it would pull a vacuum then leak down within a minute. On a side note there is a missing line on the check valve, is it supposed to go to the air pump?
      i want to say the 3 way check valve usually has engine vacuum and servo connection straight across from one another and the bottom out to the smog pump. I also seem to remember a standard 2 port one on the smog pump line. I shuffled things around on mine so the 2 port check valve is the only one in place. Just make sure if the engine side is pulling vacuum its actually getting to the servo.
      Which line off the servo were you getting leakage on? If its the one with the Y thing, thats the line to the dump valve, so make sure its the servo and not the valve. You should be able to apply vacuum to the servo and see the throttle open if its working at all.
        Is the line connected to the soup can?
          I think the po of my car messed up the lines, the bottom of the tee goes to the vacuum tree then the top right goes to the servo. I believe that line was getting vacuum and I tested the check valve from there too. Also I tested the little line from the tee to the top of the servo and thats where it leaks, so basically where engine vacuum would enter the servo.
          Edit: I see what you’re saying so if I apply vacuum to where I did it should pull the linkage back too? It did not. It seems the black piece of plastic at the end where it attached to the throttle cable can move freely compared to the linkage if that makes sense.
          Also yes the line is connected to the soup can. I actually had to buy a soup can and line for it because someone deleted it at some point.
            Pro tip when working inside car for long time..pull the door plunger out and unplug it. You wont burn your hands on any lights or drain your battery down to nothing.
            Also:
            Page 123 only tells you the vacuum supplied to the speed control is coming from the firewall mounted manifold through a black and brown vacuum line.
              The T check valve is set up properly. The plugged side is to the smog pump. I remember dealing with that on my 88 very clearly.
                Thank you guys I’ll have to look into it a little deeper.
