How do you guys ground yourselves when handling circuit boards? Would a pair of .9 mil latex gloves prevent static discharge? It's summer in Jersey and it's quite humid at times; nonetheless, I do manage to get a static shock/charge here and there.
Handling Circuit Boards Like Quarter Horse etc.....
I don't. Haven't blown anything up from static yet.86 Lincoln Town Car (Galactica).
Ditto that, I don't ground myself... but I do touch the car first to equalize myself to it... and most people will do that naturally just getting in and out of the vehicle. That's enough right there.
As someone who works around electronics regularly, I'm going to suggest NOT wearing the gloves. You're moving from place to place, and if you're building up a charge, and not letting it dissipate, you're risking more of a "zap" when it does finally release. Just touch the car body, and consciously touch things on the car that are grounded before you touch the board or components; and make it sort of a habit to put your finger on the head of a screw holding a ground strap or something.
These boards aren't as sensitive as some boards out there, so static damage is rare. Still, better safe than sorry.
Working with individual components on really sensitive boards? I've got a wrist strap and a static mat, and I wouldn't even consider dragging them out to the car. It's overkill.
Thanks. I had the ECM out of the car when I did this. I wore my .9mil gloves and everything was fine. I have more questions though. Should I duct tape over the exposed end of the Quarterhorse? Or if I am fortunate, find a piece of plastic (packaging material) to use as a cover? Or is it fine exposed?
As an electrical engineer... I can for a fact say that nitrile gloves will not protect against static buildup beyond about 4-600V. I have been shocked through nitrile gloves at work. Also, working on cars, when you get to the tuning part, you're pretty much at the glove free part anyhow. Wearing gloves is really neither here nor there with handling the QH board. The only real thing to pay attention to is that there's no loose metal to assist in the QH touching the ECM case and shorting out. That's the only real concern. Most automotive based electronics are rated to 4KV electric shock and should survive most static discharge (unless you're making those 1+ inch arcs like in winter with wool coats after getting out of a cloth car). Once again... not a big concern for these parts.
Just try to use best practices: handle by card edge or case. Avoid touching contact pins.
You shouldn't have any issues just following those 2 guidelines.
Yes, cover the end of the board to make sure nothing can contact it and short things out.86 Lincoln Town Car (Galactica).
Originally posted by sly View PostAs an electrical engineer... I can for a fact say that nitrile gloves will not protect against static buildup beyond about 4-600V. I have been shocked through nitrile gloves at work. Also, working on cars, when you get to the tuning part, you're pretty much at the glove free part anyhow. Wearing gloves is really neither here nor there with handling the QH board. The only real thing to pay attention to is that there's no loose metal to assist in the QH touching the ECM case and shorting out. That's the only real concern. Most automotive based electronics are rated to 4KV electric shock and should survive most static discharge (unless you're making those 1+ inch arcs like in winter with wool coats after getting out of a cloth car). Once again... not a big concern for these parts...1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostI've always got gloves on. Proper fit for success I suppose? I don't handle a whole lot of electronics, mostly just instrument clusters when I do. But I hate smudging them so they're always cleaned and then of course I've got gloves on to protect against stray finger oil. Those purple nitrile gloves or my mechanix heavy gloves are always on while I work. Unless what I'm touching is clean. I absolutely hate the feeling of dirty fingers and hands. The irony, right?
