the one on my Continental is bad, so I'm somewhat more mindful of them.
Battery hooked backwards, what now?! ;(
Here's an 88 EVTM:
Sent from my iPhone using Tapatalk1990 Country Squire - weekend cruiser, next project
When my NSS went bad, i was able to start it in neutral but not park. worth a shot-Phil
Ok, sofar I have tried to get 12v to red/lt blue for starter relay, nothing. I replaced it with a good set of what re from a newer 91 CV from the u-pull yard and no change, still no 12v going to the red/lt blue wire. I traced the wires to either a inline fuse or a y junction and that's where I replaced the red/lt blue wire at. One leads to the NSS and one further into the harness as the diagram also shows. I've replaced the ignition switch, no change. Should I go snag a NSS from the u-pull yard and see if that works? Could I also just jump a pin to test if it fires and to show me if the NSS is bad?? So far the wiring seems good (after changing the alternator wiring harness, was not charging since it blew the inline fuse to the black/orange alternator wiring).
As mentioned, try start in neutral. Sometimes park connection in the NSS dies. You can also disconnect the NSS and jump the start in and start out pins (don't know which ones they are) and see. You can check the power to the connector as you should have 12V on the start in line when the key is in the start position.
Yeah, check for voltage at the NSS. If voltage is there, the NSS is probably bad. Put in park and neutral and if no connection through it, replace NSS and you should be good.
find the harness to the trans, should be hanging roughly middle of the firewall behind the engine. White/pink is the wire from the key switch, red/blue is out to the relay. Check for +12v at the white/pink when trying to crank it. If you have voltage there, jump white/pink to red/blue and see if it goes. If it does, the NSS or the harness to it is dicked.
The Y split in the red/blue is where one side goes to power the ignition module when cranking.86 Lincoln Town Car (Galactica).
Thank you EVERYONE for your help and input. I have figured it out with all the help. From the engine being pulled the NSS plug was barely plugged in (trans was hanging a little after engine was pulled). I seated it fully on the NSS and BOOM fires from the key right away. So all I really had to fix was my alternator wiring from the battery being hooked up backwards and it works as it should Would have never checked there if it wasn't for everyone. I appreciate you all so damn much
Awesome! Sometimes it take a lot of work to find an easy fix-Phil
Nice. love it when it's a free fix.
