Power windows not working
    Pretty sure it's a box and they didn't have those.
      Diagram shows g1303 inside Lh front door,near control switch
      G403 behind Lh center of I/P on ground bus
      Do you have picture of the ground
        No. I don't have the 88 any more to get that pic either. There may be enough of a difference between 88 and earlier cars that the body contact for the grounds may be in a different spot. I do know that my former 88, 93, 2000 and even my 03 Expedition have ground points where local accessories are grounded in that location, so I'm pretty sure yours should have a ground point to the body there too. I think the 82 Mark VI I had also has a ground point there. Should be about an inch from the door jamb, behind the kick panel, either down near the carpet or about 2/3 the way up to the dash IIRC. Basically look for wire(s) with a ring terminal that's bolted to the body.
          Ok I’ll look and my wagon is a 1987 forgot to mention that
            Was under dash tracing grounds and found this connector with plastic cover what’s this for
              That's a new one on me. Haven't seen that one before.
                FSPVM
                Federal Suspicious Person Vehicle Monitor
                  Does it have connectors for a tripminder?
                    I don’t know i did unhook all Cruise control stuff
                      Would be interesting to track all the wires coming and going into that connector to see where they came from and where they are going. I do seem to remember a connector similar to that having wires/s for a part of the tripminder harness. But then, I'm old so there is that!
                        Tripminder harness has those funky clear covers in that location for certain years.
                          Got driver’s window working took all related connectors apart and sanded contacts.while I was doing so I came across one relay I couldn’t identify the brown connector relay any one know it’s on passenger side
                            The brown one is probably the autolamp relay. Check for a soldered wire on that metal hanger. DO NOT REMOVE THE HANGER FROM THE RELAY if it is soldered to a wire. That will break the relay. That's the ground for the coil. These are completely unobtanium. They are dual pole dual throw and technically 6 pin relays.
                            If it doesn't have the wire soldered to the clip, then I've got no clue what it is for. But I'm pretty sure that's the autolamp relay.
                              I don’t have that auto light option on my car could’ve it been just installed just in case an ad on auto lamp
                                Check the relay for that soldered wire. If it doesn't have it, it's not the autolamp relay. That's the ONLY "6-pin" relay in the car. The rest are the usual 4/5 pin relays. If it doesn't have the wire out the back soldered to the clip, then I dunno what it's for.
