On my '86 MGM, the under hood light........I can not find the mercury switch, how does the lamp go off when the hood is closed???
Mercury Switch, where is it located?
The switch is in the housing where the bulb goes. When you open the hood, the ball of mercury slides down to make contact so the light comes on. I remove the bulbs under my hoods, the switch can fail and drain your battery if the light is on with the hood closed. I have a flashlight under the seat of my cars for emergencies. WagonMan89 Colony Park
90 Colony Park
70 HEMI Daytona Convertible
Originally posted by WagonMan View PostThe switch is in the housing where the bulb goes. When you open the hood, the ball of mercury slides down to make contact so the light comes on. I remove the bulbs under my hoods, the switch can fail and drain your battery if the light is on with the hood closed. I have a flashlight under the seat of my cars for emergencies. WagonMan
The bulb socket has the mercury switch in it. The switch doesn't take up much of any room.
