Door actuator(sp)
    oe don't exist but you can get generic ones and cut to fit. Not super difficult, just kind of tedious getting the old staples out and then the new pieces trimmed and fastened on. Also have to figure out what generic material is the right shape. I've done it on all of my cars at this point.
      Water pump pliers to get them popped back in. The only time I ever drilled a rivet is when I retrofitted in a whale power lock actuator.
        Water pump pliers? There is enough room to use them? Interesting use of that tool - never thought to try them.
          I used cheap pliers in the wide jaw setting to pop them back into the bracket the one time I tried that method. Leave the bracket with the slot down so when the actuator freezes up it can (with some force) be popped out of the bracket (had to do that once too).
            I have a range of sizes. The biggest that fit for the leverage. Jaws as closed as possible for maximum squeezing power. Put one side in by hand, and you only need to plier one side into place.
              Never tried that but does sound interesting.
