Stereo Install Questions...
in the windshield/speaker problem, get the 1 way/4 way driver you need, find a vise somewhere thats bolted down, screw the ebd, bout 1/2" from the tip and make a 90+degree bend, will work then..
I just mounted the head unit's sleeve right into the dash. It holds my dash trim piece (broken tabs) to the plastic DIN adapter behind the dash. There is a little metal visible at certain angles that I'll hit with some black paint the next time the head unit is out.
Leave a comment:
ok....pics aint the greatest. but you can see how i used 2 of the mounting brackets. i used one as a spacer to push ht radio out then used the bracket that bolts it in. had to do a couple small mods to one bracket that has the circle things around edge of hole for stereo on bracket.Last edited by 87_crown_vic; 01-30-2008, 10:16 AM.
Leave a comment:
Originally posted by P72Ford View PostSorry for the confusion
Originally posted by 1987cpHey, always interesting to learn folks' names. I guess we could call you Nate Jr. or Nato II? Or how about N2?
Leave a comment:
Hey, always interesting to learn folks' names. I guess we could call you Nate Jr. or Nato II? Or how about N2? :p
Leave a comment:
Originally posted by 1987cp View PostLooks nice, cosmetics don't even clash with the interior that badly. Is that the same head unit as Nate's?
Leave a comment:
Originally posted by 87_crown_vic View Posti will get pictures of how i installed Donnas stereo. i will take a pic of the brackets and how it all went together. this is how hers turned out. figured i would show hers and a pic of mine since i do the installs.
Leave a comment:
No--mine's a Pioneer, though it looks somewhat similar to that.
Leave a comment:
Leave a comment:
Use a stereo install kit, it comes with a plastic trim ring thing that screws into where the factory brackets go, and the sleeve slides into that. Bend the tabs on the sleeve and you're set. Install kit is like $10.
Leave a comment:
i will get pictures of how i installed Donnas stereo. i will take a pic of the brackets and how it all went together. this is how hers turned out. figured i would show hers and a pic of mine since i do the installs.Last edited by 87_crown_vic; 01-30-2008, 10:16 AM.
Leave a comment:
Leave a comment:
