now we just need someone to test style 27 and get some feedback.
Door window weather stripping
By all means become a pioneer in the field of box panther weather-stripping.~David~
yes please do, we are all eager t find out!~David~
My drivers side run channel is in pieces and moves with the window at times so pretty much anything wood be an improvement at this point, On the plus side I can easily pop a chunk out to see a cross section. On a side note, is the lower reveal (where dew wipes are attatched) molding just held on by nuts (I know one is at each end - possibly some towards center accessible from inside door shell), or are there also those annoying Ford clips that never go back on to?sigpic
1986 Grand Marquis LS 2 Door
Originally posted by 86GmLsCoupe View PostMy drivers side run channel is in pieces and moves with the window at times so pretty much anything wood be an improvement at this point, On the plus side I can easily pop a chunk out to see a cross section. On a side note, is the lower reveal (where dew wipes are attached) molding just held on by nuts (I know one is at each end - possibly some towards center accessible from inside door shell), or are there also those annoying Ford clips that never go back on to?Last edited by 87gtVIC; 01-17-2009, 08:39 AM.~David~
That's really good news to hear because I'd love to replace the dew wipes like the guy did on Lincolnsonline did and from what you said it's not entirely that bad. I had a problem with the clips with the drivers side upper reveal where I never could get the clips to reattach and then of course lost them. That piece is caulked onto the car for the time being but I want to try ordering some clips from Lawson to get it on the right way. One thing I'm very paranoid about is the vent window gasket/seal.sigpic
Ahhh, my apologies. In fact you to have to mess with some metal clips. As of right now the metal clips are attached to the dew wipe material and will need to be swapped over to the new dew wipe material. This can easily be done with a flat head screw driver to remove the clips from the old material, and the use a bench top vise to squize the metal clips back onto the dew wipe material.~David~
no you have not missed that part..nobody to my knowledge has done it yet.~David~
OK update! not a good one.
Explore JC Whitney for premium auto parts & accessories, dive into car culture, & stay updated with the latest automotive events & tech trends
as of right now, and possible some time ago, style number 27 of the precision all rubber window channels has been DISCONTINUED. Which sucks because i was about to order some so i can have new window channels for my p. side window.
Style 26 is still available and so is style 20. I know 20 works, because that is installed on Toms GMGT. I just need feedback from Brandon and his Marquis, if he purchased style number 26 yet.
Either way i am going to be purchasing one of the two mentioned styles and make it work once my car is painted.
I really though 27 was the best one and almost cried when i heard 27 was discontinued.~David~
I'm waiting until after paint before I order and install Style 26, in all four doors of my Marquis. I'll be removing all the window run channels and quarter/vent windows before paint anyway, so I'm gonna take that convenient time to install the new channels. I will let you guys know afterward if they worked correctly or not, looks like it will be an exact fit though.
i think i may find out before you though. Painting time is almost here for me~David~
Originally posted by 87gtVIC View Posti think i may find out before you though. Painting time is almost here for me
By all means let us know how it works out though!
