Here's my Hot Rod/Tow vehicle It's a 1986 F250 XLT Supercab longbox 2wd truck. It has a 460 V8, T19 4spd manual transmission and a 10.25" full floating rear diff with 4.10 gears and a trac-loc unit. For a big heavy truck this thing moves!!
It has a 40/20/40 seat out of a mid 90's Ford truck, B&M shifter T-handle, Grant steering wheel, American racing aluminum wheels, Dual exhaust (Just Glass packs and megaphone tips, no mufflers or cats ).
The motor is basically stock except for a 4 hole carb spacer and an Edelbrock 750cfm carb. Since I bought the truck I have given it a tune up, removed the air injection and EGR valve/carb spacer.
Here's the pic that was in the classified ad that I bought it from.
I'll add some good pics of it later.
I'm going to be replacing the transmission with another T19(The one in it has a bad bearing ), swapping in a rear diff with 3.55 gears, I'm going to swap the stock intake for a Weiand Stealth intake and install some Hedman headers, Hooker Aero chamber mufflers, a K&N air cleaner and a functional Boss 429 hoodscoop.
